Originally Posted by
Welsh Dan
You could use a normally open relay between the positive terminals for both bulbs, and use the main beam feed to switch it 'on' to 'closed', so that when main beam is switched on dipped beam is aswell, but dipped beam will also operate on its own. In conjunction with that though I'd run a live feed from the battery to main beam, and use a relay to switch that aswell.... or use a relay with 2 switched pairs to do the job in one.
If you just join the positive terminals they'll all be on or all be off....
