Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
Thread: Help
    User belly257's Avatar
    Dec 2007
    cumbria
    900
    Default Help
    ive got my nova in bits at the mo, struggleing where to put the wires that come off the electric window loom into the back of the fusebox, done a search but can't find out heres the wires:
    these i guess are the live and switched live, but heres the back of the fusebox:
    anyone help!! thanks
    Senior User Shaun_O'Donnell's Avatar
    May 2006
    Falkirk - Central Scotland
    1,903
    Looking at the front of the fusebox (Fuses facing you), I am sure the go to the far bottom right.
    Dec 2007
    cumbria
    900
    Quote Originally Posted by Shaun_O'Donnell
    i thought that aswell as there is a ignition live there but no permanent live
    May 2006
    1,903
    There is no permanent live for the windows, just ignition live & negative.
    Dec 2007
    cumbria
    900
    thought these two connectors pictured are a constant live and a switched live? and the earth is near the switches?
    May 2006
    1,903
    Quote Originally Posted by belly257
    I forgot about that earth near the gear selector, been a wee while since I had a mk2 and electric windows. Apologies.
    Hopefully someone with proper knowledge will sort you out soon.
    Dec 2007
    cumbria
    900
    ok mate no worrys thanks for your help
    User stevenf's Avatar
    Sep 2004
    berwick upon tweed, northumberland
    1,234
    iirc the two wires clip into the bottom right hand side of the fuse box in the bottom two slots. they will only go in one way as they are slightly different shaped. hope this helps. if not i can always go out and have a look at mine for you
    Dec 2007
    cumbria
    900
    Quote Originally Posted by stevenf
    thanks mate your right, that is where they go,can't see how a fuse goes in there though, got abit drak now will have to finish it tomorrow thanks
  10. #10
    Sep 2004
    1,234
    iirc the live wire runs off to another fuse in the fuse box. follow the wire from the back of the box and you will find where it is
