prety much as above, any idea on the cause ? could i be missing a wire or maybe the relays had it
I'd say relay or possibly switch
"It'll be done when its done"
everything was good before i disconnected the rear wiper and chopped a coupla wires out for it, could that have effected anything ? one wire went to the relay and the other to the switch
edit : that needs re-phrasing, everything was good untill i tried wiring the cuircit to switches.. im guessing i put power down a line that i shouldnt have and killed the relay ?
I would say yes if all was working fine beforehand.Originally Posted by jimbob-mcgrew
ill get back with the wiring situation.. tell u which exact wires ive chopped out
ok, from what i can tell my wiring cuts are fine, just the rear wiper from the switch, thought i cut out the washer too, but that still works.
anyhow.. its the black and yellow wire that goes to the relay, when switch is on intermittent it gets power thru it to the relay, relay makes a click noise everytime the circuit gets engaged, try put an earth thru the same black and yellow wire while the circuits off and it makes the same click, sound like a relay fault ?
cant tell which wire is single speed or intermittent tho as of yet.. cos they both do the exact same thing, blue and yellow they are, white is deffo double speed.
where can i get cheap relays from and how much ish are they ?
relay:
ITALAMEC
made in italy
12v - 313
PA 66
90069864
yeh tis fooked, opened it up and found a break in one of the circuit lines on the board
if i had any solder i could prob fix it
used last of it t'other day ! bollox
talkin to myself again
go to the scrappers and get realy from a mk3 golf , will have 99 on it , some golfs have them , other have 19 which is no good
the intermittent wipe is programable , so you can set it to what ecer time delay you want
