anyone used mega squirt on a c16se? can you use the stanard crank sensor or do i hav to use a diff trigger wheel and sensor?thinking of buing one verion 3 i think with wide band
Deffo a question for the MS forums tbh.
you can use the VR sensor on Gm systems, and I do believe you can use the crank trigger pattern too. as said, best check up on the MS forums
It depends which MS you have. Some can use vauxhall 60-2 triggers and ignition systems, other versions cant.
"version3" is the board version btw, not the actual version of Megasquirt.
Old XE track car
cheers
http://www.extraefi.co.uk/
cant recommend him enough. give him a call and explain what you wish to do and he will sort you out
