have ditched the wiper stalk, and want to run front wipers & washers on switches, but i cant bloody figure out how any of it works, not even the washers !
right so this is as far as ive got:
black & purple = switched ignition live
yellow = single speed
white = double speed
brown = earth
blue = no friggin clue but it goes to the relay (can put power down the line)
black & yellow = some part of the relay
black & grey = line to washer pump terminal (can put power down the line)
2 x black & red = line to other washer pump terminal (can put power down the line)
ive rigged up wires on switches so that single speed and double speed were working, but they stopped on the switch, not on the relay as they should, cant find intermittent either. i tried almost every combination i could think of with the wiring, even putting 2 different wires together on different switch terminals.. and im lost with the washers cos nothing happens regardless of how u power and earth those 2 lines (but may be the pump, will try another one later), somethings missing from the equasion thats upsetting all my efforts, something to do with the relay wires i think. can anybody help ?
