would i be ok to ditch the intermittent and full speed, and just run single speed with squirters for the mot ?
also while im here, anyone know which wires on the stalk do what ? itll save me alot of time, cheers
edit : ppfttt.. dickhead.....
Don't see why not, but why
I find rainX is good stuff, if you travel fast enough you don't need wipers depending on the precipitation:D
Regards
Royston
precipitation... jeesus: me no speaka englaiseh sinjour
'why' u ask... mainly cos of where ive got the choke mounted, the stalk is in the way, but im hoping to loose some weight too. from the switch, wires and possibly another relay, not sure how single speed works, but i would assume a relays needed for intermittent.
I would expect it to fail IF the stalk still had the intermittent and fast positions and those did not work, as the manual states:
...i.e. if you swtich the wipers on to intermittent, and nothing happens, regardless of whether or not they work on the normal position I would read that as a fail.a wiper does not continue to operate automatically when switched on
However, if you ditched the stalk and had a on/off toggle switch, this would then be a pass.
Does that make sense?
[edit] Having said that, Alex's pooloo passed an MOT (eventually) and her wipers used to stop when you hit the "fast" position . However, if I was the tester I would have failed it for that...
"It'll be done when its done"
Is worth all the hassle for such a small saving?Originally Posted by jimbob-mcgrew
(┌∩┐(◣_◢)┌∩┐)
taking a poo would be more benificial IMO
My Rebuild
you could be a smart bastid and fit a rain sensor on the scuttle panel. auto wipers.
jack - yeh would be ditching the stalk and re-wiring to toggle switches (running out of space on my dash !).. didnt make that clear.. ta. can i ditch another relay doing this too ? ive only got 2 left, cant remember what they do.
single speed wipers would be a pain in the **** to drive with. if you ditch the relay and switch youll loose the ability for the wipers to 'auto-park' so it will be the ultimate PITA. for a VERY negligable weight saving.
......ah .. i wasnt expecting that.. cheers for letting me know.. i WILL NOT be ditching the relay in that case
