my heater motor only works on 3 but only spins as fast as if its on 1 does anyone know how to fix it
spray the bearings with a lube like wd40
tried that
does it turn freely by hand?? if so you need to check you have feed to each of the wires with each step of the switch
yes it turns freely by hand will put a mulitmeter on it tomorrow and test it thanks
do you have a haynes so you can see which switch is which?
yeah i got one
good good. if you do have a feed to all the wires then its probably burnt out, which does happen. altho check the continuity of the earth as well
cool will do thanks
have you got a mk2 dash in a mk1 car?
