i noticed none of my brakelights were working so i changed the bulbs
but still not working. anyone got any idea what it could be ?
Have you tried other lights in the same cluster (indicators etc)
Just saying cause I had mine out other day and didnt push the plug far on enough, silly boy.
maybe a fuse ? or corrosion on the fuse holder terminals ?
maybe both bulbs have popped
if youve got a volt tester/light tester, u can check to see if currents going thru the fuse holder and also going down the wire to the bulb holder, if u dont have one, u could always pull the rear boot light out temporarily, and rig a long bit of wire to each terminal on the light, to make yourself one, can be done with speaker wire or whatever as a temporary thing.
check the brakelight switch if all else seems fine
^ aha yeh brian, i forgot that, might be the culprit
ok i will do as uve sed and get back to you
thanks
sorted all it was, was a fuse
