Im in the process of removing electric windows from my scrap nova and ive got the loom,swithces,motors and glass is there anything else i will require to put it on my other car?
Cheers Craig
Cheers Craig
Glass is the same in both cars all you need is the wiring, switches, and the door regs, and i also found if you keep the wing bolts off the donor nova you can use these to bolt them into the doors rather than pop-rivets so theyre easily removable should needs require
Cheers SRspudly dint wanna scrap it then realise i needed summets else
No worries bud theyre really easy to fit aswell!
all you will need is the wiring loom the switches and the motor and that should be it i think
