is it the + or the - side of the coil i join to the 6 dial clock speedo? dont want to bugger them up before they go in
for the rev counter i take it
what was i writing should get in the habit of proof reading before postingfor the rev counter i take it
btw yes i mean the tachometer
im pretty sure it the earth side and the green wire
ok cheers mate ill have a look
As you look at the square black plug from behind (as in the side where the wires go into it) its the bottom right terminal you want iirc!
yep it works, cheers mate, errm take it i need a diffrent oil pressure switch or do i just run another wire?
To make the oil pressure gauge work? yep you need the correct two pin sender that bolts in place of the standard oil pressure switch.
