can some 1 help me!!!! ders no wire to conect to the rev cownter dose any1 now where it gose?? it a mk2 1.2 nova h reg?????
Hmm no text typing would be a start
If you plug it in it should work straight away...Mines did
come on....
those arent even words
If it doesnt work then you have to run one from the coil yourself.
If you want to last around here i would bin the text typing
More exclamation and question marks make this thread of higher importance than others also.
rofl @ 'ders' :D
http://www.pngclub.com/forum/showthread.php?t=104573
check that one mate
the rear of your dials the same as in that picture? i think the 1.2i actually already has a wire on the loom, and i dont think its hard to run a new one down to the appropriate place, i read it in a thread on here somewhere yesterday mate
try the search function at the top too
der mite be da grn wire in da l00m bhind da dash, av a luk 4 it. If nt, put 1 in from da ciol negertave 2 da back ov da (croco)diles, cant remememembar wat pin it goz in2 but av a luk in da dashswap giued in artikals 4 info on pin lokashuns
"It'll be done when its done"
The wire should be connected to the plug which relates to the top left connector in that square block of copper connections on left. If you follow the copper you can see it goes to the back of the rev counter.
5 min job tops.
