This problem happens most times I use the wipers, but is not consistent in what happens!
Normally when turning my wipers off, or when I've just moved the stalk up without clicking it in to position 1 to turn the wipers on one once, the digidash will either: flicker the speed indicator to 0 and back again, increase the revs and drop them back to where they were, or initiate a full start up sequence again.
It seems to happen when the wipers sit back at the bottom of the windscreen, and not when I move the stalk.
I've also noticed when I turn the wipers on the dash dims somewhat, probably more than I'd expect but this may be normal.
I've tried the original stalk (Corsa ones in atm) and a new relay without success.
Any suggestions?
