Got a bit of white on the walls.
https://uploads.tapatalk-cdn.com/202...e2aac44b6a.jpg
https://uploads.tapatalk-cdn.com/202...b58afcd75d.jpg
https://uploads.tapatalk-cdn.com/202...69fc1c5471.jpg
Second coat required
Beer fridge?
Car will be at VBOA, but won't be running as the wiring wont be done.
Be good to catch up with you mate.
Busy day today,
when I moved the car off for wiring a few weeks ago there was a puddle of oil under the car.
Couldn't really understand it, as when it's running there was nothing pouring out....
Believing it to be crank seal we whipped the box out in 45 mins flat.
https://uploads.tapatalk-cdn.com/202...2706f17e12.jpg
https://uploads.tapatalk-cdn.com/202...fb22f5432d.jpg
Despite a bit of oil out the bolt holes the seal was surprisingly dry... got the air line out to clean and blow it of, as the nozzle got onto the sump join to the block an explosion of oil out the crank bolt holes!! Bloody sump leak.
https://uploads.tapatalk-cdn.com/202...e094e528cf.jpg
So off with the sump, 3 bolts round that end loose!! School boy error when I fitted them, no sealant on the threads at all.
https://uploads.tapatalk-cdn.com/202...e06e30c31d.jpg
Clear to see!!
Bit of cleaning and some 3 bond
https://uploads.tapatalk-cdn.com/202...be3a961c9e.jpg
Then I snapped a bolt putting it back together!! With luck on my side (for a change) I managed to work the broken bit of bolt out with a pick!!
Clean and reseal, back together.
https://uploads.tapatalk-cdn.com/202...0c7b5ddda7.jpg
Flywheel and box on quick wash and it's ready to be a paper weight at VBOA!!
Snapped a sump bolt!!! How tight you doing them!?
You don't know your own strength...[emoji1787]
Houses arms are calibrated. Unfortunately the calibration is between small ogre and large ogre.
Piss off pal.
