Really? Mine had some punctuation marks removed so a few bits didn't make sense.
writer? Or editor?
Writer. I'l find it one day.
update
The rest of the engine got removed and stripped down, a trip to visit Philip so he could sort out the overbore to 87mm, crank check(which then got polished) and the block had a light skim.
http://i193.photobucket.com/albums/z...pswkeuptjr.jpg
He did give me some bad news in regards to the omega pistons I had bought second hand, which was that white metal was once present across the gudgeon pin, putting wear marks into the piston. New gudgeon pins may have been fitted but a light tapping in the engine may occur, I wasn't too happy with this so I then bought a set of new 87mm wossner pistons.
http://i193.photobucket.com/albums/z...pslkurabhf.jpg
Following the instructions provided with the pistons, I gapped the rings and then got the pistons fitted to the rods.
http://i193.photobucket.com/albums/z...pssu7sc2c1.jpg
http://i193.photobucket.com/albums/z...psovovrb8o.jpg
Crank and rod bearing clearances got checked with plastigauge.
http://i193.photobucket.com/albums/z...ps1fpnjlxz.jpg
The block and crank then got washed off ready for assembly with new bearings.
http://i193.photobucket.com/albums/z...psauzrzpie.jpg
z20leh/vxr oil pump fitted, with the original oil cooler sandwich plate from the c20let. For reference, the front crank seal needs to be fitted with a c20let seal.
http://i193.photobucket.com/albums/z...psk6ejzjue.jpg
New 8v baffle and a z20 to c20 oil pick up pipe fitted.
http://i193.photobucket.com/albums/z...psyzzvl7sj.jpg
Pistons slipped in.
http://i193.photobucket.com/albums/z...ps3a0kqtt4.jpg
Various other parts fitted, starter, alternator etc.
http://i193.photobucket.com/albums/z...psbuillzs4.jpg
Alternator had a freshen up before fitting.
http://i193.photobucket.com/albums/z...psevhak864.jpg
Gave the lifters a clean out.
http://i193.photobucket.com/albums/z...psc70swwgw.jpg
Head on and torqued, manifold, cambelt etc.
http://i193.photobucket.com/albums/z...psdaaasggf.jpg
Jonlem had pointed out over on FB that my idler was the wrong way around. I have since checked all the times I've built the motor up and it's always been this way. Never the less, I did correct it.
http://i193.photobucket.com/albums/z...psgopopuvf.jpg
The inlet I made is now also on.
http://i193.photobucket.com/albums/z...psr0m4wvgn.jpg
Rose jointed alternator adjusted worked a treat.
http://i193.photobucket.com/albums/z...psyuxuqwji.jpg
Before I made my inlet I read a couple of WIP threads with how they managed to still use the 3rd outlet of the 3 way hose. I'm unsure if it would cause an airlock or higher engine temps, but if it was there from factory then i thought it would be best to have it.
An inch to 10mm adapter was sourced and fitted.
http://i193.photobucket.com/albums/z...pskaxaeosp.jpg
A shiny heat shield was made to stop some heat going to the rad.
http://i193.photobucket.com/albums/z...psrsiv6817.jpg
The engine complete, awaiting to be fitted.
http://i193.photobucket.com/albums/z...psva6jq968.jpg
One empty hole.
http://i193.photobucket.com/albums/z...psjvzixwnb.jpg
Thanks for looking.
Brucer
That thing is mint, the engine bay looks alot like Benn's
Looking well!
Shiney pistons!!!!!
I would earth strap the alternator, I had issues with arcing across my rose jointed adjuster!!
wow its out !!! I need to look on here more often.... I love this little blue beast :thumb:
