if it dosnt have an immobilisor no you dont
What wiring to i need to take out the donor car its a 1.6 corsa sport engine is x16xe please help .
just the engine loom that connects to the ecu, you dont need the starter loom, youll need the bit that screws into the gearbox too if it has an immobilisor
Also a silly question what do you do with the fuel lines and connectors.
I'm putting into a carb model.
Get the hose connectors off the donor car that connect to the fuel rail, there's 2 the return and feed and then join them onto your new copper pipe or whatever your using
Right I've got mine in and wired up. Took it all out of the donor Tigra and using the same ecu chip and transponder. It fires up and cuts out after a second or 2? The purple relay clicks on then clicks off and the engine cuts out. It did do this a couple of times in te Tigra so I'm gonna try a new relay tmoz. Any other ideas people?
start a thread in the mechanical section for a start. people will help you
i will, just thought id try here too,
Anybody got the part number or a picture of the alternator belt tensioner that you need from the Corsa Sri 16v? As that's all this thread is missing.
I used the following parts for my wide belt setup
90571112 - Bracket (approx £50)
11085834 - Extra bolt for the bottom of the bracket (approx £1.70)
90412884 - tensioner (approx £110)
11098351 - bolt for tensioner to alternator bracket (approx £1.70)
93182243 - Alternator belt (approx £25)
http://www.cartensioners.co.uk/produ...-Model-Product
Cheaper alternative for the tensioner.
