All finished just wants paintinghttps://uploads.tapatalk-cdn.com/202...0b99e457a4.jpg
Sent from my SM-A105FN using Tapatalk
Been very busy trying to get everything in order before the dyno day . Trailers all painted now . The top slick is the size im going to the bottom one is whats come off . Bearing in mind the bottom one is 9 inches wide . New wheels should have a much better roll out . Fitting twin pumps to deal with the new injectors and also changed to e98 ethanol fuel . New cams and pulleys fit . Fingers crossed it makes some good numbershttps://uploads.tapatalk-cdn.com/202...8c69976909.jpghttps://uploads.tapatalk-cdn.com/202...b2bace88e9.jpghttps://uploads.tapatalk-cdn.com/202...4f2535bac1.jpghttps://uploads.tapatalk-cdn.com/202...6e00c2c3da.jpghttps://uploads.tapatalk-cdn.com/202...2a77f684ee.jpghttps://uploads.tapatalk-cdn.com/202...522eb54384.jpg
Covered trailer is cool, as is buying your fuel in kegs, haha. Head rebuild all finished then?
Yea all work done mate . 11th of april for the dyno
15mm.id ptfe no excuse now to not have enough fuelhttps://uploads.tapatalk-cdn.com/202...1e592a0765.jpghttps://uploads.tapatalk-cdn.com/202...525be93955.jpg
Never have enough fuel! Progress looks good mate
New stainless steel filter and lambda controllerhttps://uploads.tapatalk-cdn.com/202...7e1c7aaa1a.jpg
Mine are mounted to the flat floor . The pumps should be gravity fed from the tank and not having to suck the fuel in . Having said that i did used to have my pump up in the engine bay but it wasnt ideal and just makes the pump have to work harder .
Glad I asked that.
So I need to have my pump lower than the tank outlet which is good.
Cheers for that.
