There is one thing you're not going to do before Brands.... and that's Send it. [emoji1787]
Yeah I'm pretty sure it's one piece Boff, I'm looking at other options with Quaife, seeing if they'll offer different 4th 5th ratios.
Seeing if I can close the gap between 3-4-5 as the jump from 3-4 is quite big and again 4-5.
I doubt I'll get anywhere, only other option is more torque!! Hahaha
Well,
The good
https://uploads.tapatalk-cdn.com/202...7953ae96d8.jpg
https://uploads.tapatalk-cdn.com/202...7923734cbf.jpg
Ignore the GP bit, it was the Indy circuit, it's just how the software on the dash sees it.
But 54.86 is nearly a second quicker than my previous best of 55.79, which I'm over the moon with and 4 laps under that 55.79 I'm happy with too.
I watched a video round Brands with a mate of mine who we sponsor to race in the Thunderbike Extreme and Ultra with BMRC, he's won both championships this year.
Our Apex speeds were similar, he brakes later and gains time on the accel out the corners, so I changed which gear I'm in for a few corners and broke a lot later into paddock hill and was on the gas up through Surtees and held the revs in each gear a bit longer. I was also leaning hard on the diff out of corners, which I feel I'm really learning how to use now.
I should have a data log that I can compare to the log from my 55.79 lap to see where I'm quicker.
And then The bad
https://uploads.tapatalk-cdn.com/202...c01b4781a5.jpg
https://uploads.tapatalk-cdn.com/202...b0253d9b0d.png
Got back to the workshop at 13.45 and engine was out by 16.15, ramp makes things so much easier.
Box won't stay in 4th, jumps back into 3rd as soon as the power re-applies, even using the clutch as soon as you let the clutch up, it says no.
https://uploads.tapatalk-cdn.com/202...b677c288d0.jpg
Normally LSD plate wear deposits, nothing horrific.
https://uploads.tapatalk-cdn.com/202...6c08705df3.jpg
5th gear dogs (on the underside of the selector on the right forgot to get a picture) are immaculate, barely any wear at all.
I'm thinking it might be a repeat of the issue the box had when it was first installed, where it was selecting 1st and 2nd at the same time as you shifted, which Quaife fixed FOC.
It's been clunking a bit from 3rd to 4th for a while, which I thought was shift cut related and have been playing with those settings, so now I'm thinking it's the same thing as the initial issue it went to quaife with, albeit on a different gear selector and it's worn the dogs now to the point it won't stay in gear.
You can shift through it to 5th (with the clutch dipped) and it'll stay in 5th
So back to Quaife it goes.
Although I'm missing data, this is the 5th timed lap of the second session
https://youtu.be/dyiqnVqjMZY
Shame about the gearbox mate, but looked like you were flying , I’m loving the data logger something I really should invest in
