Getting somewhere now with the wiring https://uploads.tapatalk-cdn.com/202...529618d37c.jpg
Just the plugs to wire into for the Engine Loom, Light Loom and Car loom. Easy to unclip everything if I ever want the dash or engine out.https://uploads.tapatalk-cdn.com/202...d9f3b9ad49.jpg
https://uploads.tapatalk-cdn.com/202...766b358b81.jpg
Engine loom finished. Not much with only running carbs. Alternator, Starter, Oil Pressure Sender, Oil Pressure Light, Oil Temperature, Water Temperature, Coil & Crank.
Some photos of the loom, all done in over braiding to keep it neat and tidy.
https://uploads.tapatalk-cdn.com/202...1ff5b8a99f.jpg
https://uploads.tapatalk-cdn.com/202...b12c9913af.jpg
https://uploads.tapatalk-cdn.com/202...914da774f3.jpg
https://uploads.tapatalk-cdn.com/202...54c8291bc4.jpg
Haven’t had any luck with starter motors. The first starter motor that came on the engine, was worn out and lazy and the original. Had another 2 starters in my spares that I’d got from my old rally car a few years ago and they were also both not working. New one ordered which should be here tomorrow afternoon so we can finally crank the engine over.
New starter motor on and it cranked up no bother. Engine & Spot light loom are finished. Just Front lights & rear lights to start and a interior loom to start which has Fuel pump, Intercom, Fuel Sender, Interior light and Map light.
Bought a 9” Comex suction fan to replace the standard fan. Much neater and plenty of room compared to the old fan. https://uploads.tapatalk-cdn.com/202...b891f600e1.jpg
https://uploads.tapatalk-cdn.com/202...84d7f3a977.jpg
https://uploads.tapatalk-cdn.com/202...d6b476c81c.jpg
Heated screen is now inhttps://uploads.tapatalk-cdn.com/202...2e96645f5e.jpg
Lighting loom is all finished as well, H4 LED Conversion and all other bulbs around the car are LED.https://uploads.tapatalk-cdn.com/202...25721d48a7.jpg
https://uploads.tapatalk-cdn.com/202...b46d6d9b77.jpg
https://uploads.tapatalk-cdn.com/202...575b30feab.jpg
Almost there!
Where’d you get the heated screen from please?
