So I’m assuming you don’t need the end trimmed for wheel clearance any more then?
On a related note, when you’re adding in castor on your setup, how much movement forward in the arch can you get? Are you bottom arms on rj’s to allow it to angle?
Hey Simps,
We're both running the fully adjustable front wishbones, with RJ's on the bottom arm and on the tie rod.
Iain will have some better pictures than me but I can get some if you're interested to see.
https://uploads.tapatalk-cdn.com/202...83fd2d9707.png
https://uploads.tapatalk-cdn.com/202...71c9835edc.png
From my old nova shell, best I could find!!
The reason for asking is that for mine car I’ll be running full rj’d nissan arms etc and ideally would like to add quite a bit of caster and potentially move the wheel forward in the arch.
I was more curious as to roughly how much the wheel could be moved forward - 10mm? 20mm? And whether you find it eats rj’d because of the angle they are under??
Ah ok mate, I've never actually looked at how far it's moved the wheel forward over standard, I'll ask Ben and see what he says, I know that I've not used a set of RJ's in 3 years of them being on the car.
I think our limiting factor is driveshaft angle, bumper clearance and not RJ angle. I'm about to get mine 4 wheel aligned and I'm get 5 degrees of caster and get some photos of the RJ angle.
I never trimmed it to begin with, my wheel has taken out a section of my current bumper from rubbing but nowhere near enough to warrant that sort of trimming!
As House says, RJs are perfectly happy where they are. Shaft angles seem pretty happy too as we've gained castor both on the topmount and the tie rod. Limiting factors seem to be bodywork, although I recall my mate's mk2 Astra the shaft rubbed a hole in the oil cooler sandwich plate so watch out there too.
http://iainel.co.uk/images/forums/WheelCastor.JPG
Great info, thank you! I can see the wheel is well forward in the arch.
With mine being rwd I don’t have shaft issues. I’ve set my engine & therefore subframe quite far back which means so does the suspension. I’d done this “assuming” I could centralise the wheel again with castor.
Is the rear arb you have fitted come from ebay?
https://www.ebay.co.uk/itm/182032468899
And have you attached it with clamps?
