And it?s back out again, oil leaking from the crank seal and end cap :-/
I suppose the good thing is that this is the engine I?ll be using in the nova so it gets all the problems sorted out now
https://uploads.tapatalk-cdn.com/202...50dfcc1e49.jpg
https://uploads.tapatalk-cdn.com/202...44e6acbcb5.jpg
https://uploads.tapatalk-cdn.com/202...596ea99d31.jpg
Changed a fair few of them myself!!!
Always used the genuine ford sealant in the end cap and a smear on the sump gasket, not had one leak yet, but they'll just find somwhere else to leak, it is an old xe after all lol
All Vauxhall's leak mate!!
Then it was new brake lines, new rear load compensation valve, new fuel tank https://uploads.tapatalk-cdn.com/202...ff79c3df7f.jpg
Nice to see your still active on the forums Allan I'll be honest this is the first time I've had a proper look on here for a good while. I'll try to visit more often as reading through a projects thread is much better than Facebook posts, I didn't realise you'd had such a ball ache with the engines I knew you repaired the cracked block but didnt know you had the engines in then out then in and out again lol, I hope you get the astra out and have some enjoyment from it soon.
