I was thinking in engine bay or passenger seat area!
No room in the bay mate and it cant be anywhere inside the car.
New 1300cc injectors on the way from cp injection. And swapping from methanol to ethanol https://uploads.tapatalk-cdn.com/202...63d5af4b4b.jpg
Sent from my SM-A105FN using Tapatalk
Injectors turned up super fast .
A bit more work done on my tube 60mm wider rear beam https://uploads.tapatalk-cdn.com/202...ae74dbcc96.jpghttps://uploads.tapatalk-cdn.com/202...f99bf808ff.jpg
Looking forward to seeing the beam progress!
Were you struggling for fuel delivery or is this a pure power move? [emoji3060]
Whats the deal with meth to ethanol? Not something I know much about!
There is quite a lot of science behind it that is well over my head but basically pump fuel ratio is 14.7:1 .methanol ratio is 6.5:1 and ethanol is 9.1:1 . Cars will usually make good power on pump fuel however this is limited once you start to detect knock . Running methanol burns much much cooler so you can make a lot more power without knock but you need to run 2-2.5X the amount of fuel . For me to do this for my next power goal I would have either had to go with massive injectors I mean huge or run 8 1300cc injectors . The tuner has said if I go over to pure ethanol I will get away with 4x1300cc injectors but still benefit from its cooling effects . One other thing is I won't have all the chew on I have at the moment of having to refuel with gloves n glasses n shit on.and flushing the system after each track day. But yea these are proper motorsport injectors so stainless internals and a much better spray pattern than the deka 875s I was previously using .
Mate the lad out of the machine shop came in last week and I said I'm building this for my car I just need a hand to lift this onto bench .he thought exact same he was like isn't this a bit heavy for a track car hahaha . Looking at ordering the berrisford alloy hubs and brake setup for it . And the fcs speed trigger wheel for the sensor
