I messed up a little........
Guess what dick head didnt cover his car before grinding so ended up with grinding dust all over his car that then turned to millions of rust spots all over.........yeah that dick head would be me lmao.
So set about clay barring and machine polishing the car, luckily it all came off after a few hours of going at it. Lesson learnt, I'll be covering the car next time I do any grinding or welding.https://uploads.tapatalk-cdn.com/202...e962022554.jpghttps://uploads.tapatalk-cdn.com/202...2d7db652ec.jpghttps://uploads.tapatalk-cdn.com/202...bd63596a45.jpg
Got the drivers side inner wing and flitch panel done today, not as many pics of the process but it was same as passenger side I posted.
Also my GM front panel turned up today so I did a quick test fit and make sure it all lines up and its bang on, well happy with it. Just shows its worth spending the extra money for the proper parts.
I'll get that welded on next weekend then I can start smoothing all the engine bay ready for spraying.
I'm going for smooth seams so using a little filler to do ithttps://uploads.tapatalk-cdn.com/202...6e7415cfbd.jpghttps://uploads.tapatalk-cdn.com/202...0e7d19e163.jpghttps://uploads.tapatalk-cdn.com/202...e9af1b9dcf.jpghttps://uploads.tapatalk-cdn.com/202...1329bf6f91.jpghttps://uploads.tapatalk-cdn.com/202...9f8cd0dbd1.jpghttps://uploads.tapatalk-cdn.com/202...df562896dc.jpghttps://uploads.tapatalk-cdn.com/202...611dbc1082.jpghttps://uploads.tapatalk-cdn.com/202...f291d8c862.jpg
Looking good pal defo worth getting gm stuff if possible worth the extra money all day long.
Looking good mate, always worth the extra money for genuine panels
Got the front panel welded on today.
Also did the chassis leg mod
I just have 2 plates to do on the bottom of the chassis leg where it meets the front panel then thats all the welding done.
I can now starts tidying up the bay and smoothing it then spray.
Just need to bend the clutch hole down
I ground down the welds on the front panel and put some zinc primer on until I primer the whole thing.
Group down the welds on the chassis leg mod then seam sealed across which will be smoothed out when dried
I'll crack on next weekend https://uploads.tapatalk-cdn.com/202...aa39a3715f.jpghttps://uploads.tapatalk-cdn.com/202...5981ef4dff.jpghttps://uploads.tapatalk-cdn.com/202...40a908f09a.jpghttps://uploads.tapatalk-cdn.com/202...a1384d121d.jpghttps://uploads.tapatalk-cdn.com/202...aca0ae0abc.jpghttps://uploads.tapatalk-cdn.com/202...d41c9c5057.jpghttps://uploads.tapatalk-cdn.com/202...f03c6bd2d2.jpghttps://uploads.tapatalk-cdn.com/202...b9964f4601.jpg
I liked it up to the point you applied the seam sealer. Why not mask either edge and use a brush for a factory look?
Dont worry it will all be smoothed out lol
Looks messy at the minute but have faith haha
I was rushing to be fair as I had to be somewhere so quickly wacked it on
Good work pal. Cracking on now are you smoothing the bay completely?
Yeah thats the plan mate, smooth the seams out.
Want it looking as smooth as I can get it really
Use the black fibrofill pal its flexible so wont crack followed by a light skim of filler.
