Good shout that, corner speed/apex speed works the same way I guess. Like I say I'm new to working all this out!!
I figure the biggest gains now are going to come from my driving skills, hence the use of data logging
https://photos.app.goo.gl/mPs2Giymy9yHnWTLAThe green line is with 120kg passanger. The red and blue is without passanger and the car was 30kg lighter, so 150kg lighter overall.
https://photos.app.goo.gl/itoGy6X7jTM6jz3y5
Here are the maximum values. With the red and blue I was on the limiter in 3th gear for 20m long. You can see there is not too much grip for the tires, max 1.15-1.17G, once was the peak 1.2. the longitudinal max 0,6G is jut out from the pit lane in 1th gear.
https://photos.app.goo.gl/M2mLtV8TUdBMkddy9
At the minimum value is one very important thing, Longitudinal Acc at the green is 0.7G clear sign I did not push the brake really... Next time on the red and blue aroung 1G what is ok for the R888R. Hard braking is important for the races.
What you can see from the graph there is more interference between the red and blue lines, and just 0.01s difference on the laptime, there is much more in the car, so I must practice more.
Pretty cool to look at Tommy. It's great to use to see where you can and cannot make up time, like you say you can see how hard you are braking and the corner speeds
Post used to get picture order for the next post
Entry speed turn 1 Our entry speeds are within 1mph and house is 0.16 seconds ahead at this point of the lap.
https://uploads.tapatalk-cdn.com/202...6fff244608.png
Exit speed turn 1 Iain's exit speed is 3mph higher than House's and we can see that Iain has opened a gap of 0.12 of a second so just through turn 1 Iain is 0.26 quicker
https://uploads.tapatalk-cdn.com/202...ffd0c65f22.png
Iain braking point turn 2 at the braking point Iain's speed is 114.5mph and he has pulled another 0.08 seconds over House.
https://uploads.tapatalk-cdn.com/202...5d59dfbcfe.png
House braking point turn 2 speed is the same as iain's but braking is much earlier than Iain's and although they brake with the same force, deccel rate is the same, House brakes for longer and slows more for turn 2
https://uploads.tapatalk-cdn.com/202...731495cd4f.png
Braking point turn 3 is the same for both cars but Iaiin's speed is 6mph higher at the braking point.
https://uploads.tapatalk-cdn.com/202...d556df619c.png
Apex turn 3 iain's apex speed is 3mph higher at turn 3 and he's opened up 1.58 seconds over house.
https://uploads.tapatalk-cdn.com/202...8a02c72e36.png
Apex Speeds Turn 4 iain is faster down through turn 4 by 5mph with a lead of 2.16 seconds
https://uploads.tapatalk-cdn.com/202...6a8d62e9d4.png
By the end of the lap Iain has pulled out 2.362 seconds and House has some work to do in the braking zone of turn 2 and down through turn 4.
Javelin sprint series went well at Cadwell Park, it was wet, no grip, broke the car on the sighting laps
https://uploads.tapatalk-cdn.com/202...9fded9ed46.jpg
https://uploads.tapatalk-cdn.com/202...2c5d6cf2b8.jpg
https://uploads.tapatalk-cdn.com/202...0199f25169.jpg
New shafts on order, in the meantime I'm back on an old shaft for Brands on Monday.
Yonkers!
You would think that would be more likely to happen in the dry with too much grip? Or was it spinning in the wet then suddenly got grip??
Good effort sir [emoji1319][emoji1319][emoji1319] haven?t seen many break like that!
What sort of maximum speed were you doing at cadwell before the shaft went? Would like to have a go at cadwell on a track day but don?t know if I?ll be screaming it?s head off with a 4.8 CWP
That's what I was thinking. Either that, or the shaft was on its way out already and didn't need much persuasion to break. That said, the break itself doesn't look like a typical repetitive strain crack you often see on bits that give in to repeated overload situations.
Thoughts anyone?
Well, I did the sighting laps at Cadwell it was terrible, no grip at all, and as we all know I had a little off at Cadwell so something told me (sixth sense) something wasn't right, started getting an odd misfire, so I thought as it's pissing it down I'm done, on the trailer and home.
Got home, fiddled with all the plugs in the bay and went in a quick road test, 800 yards from home, second gear straight wheels, maybe 50% throttle.....BANG snappy snap.
2 random people stopped to ask if I was ok and one of them towed me back home!! (She was a legend)
It's snapped exactly at the circlip groove, now having spoken to Berrisford he said to me they all go there as it's the weakest point, it also had a square edge groove creating right angles in the bottom of the groove, stress point!!
Other shafts of mine have also started twisting
https://uploads.tapatalk-cdn.com/202...a0fde19477.jpg
The new shafts from Berrisford have a slimmed down centre section (pics to follow) that apparently moves the stress away from the circlip groove and they'll be heat treated properly.
HHMS do it the other way, they move the circlip to the outer end of the shaft meaning no stress on the circlip groove. They also rotate the inside of the CV so the groove is on the inside, all great stuff. The only issue is that you have to use their CV's at ?128 each!!!
So I'm going with Berrisford who have an excellent rep for making shafts and we'll see what happens!!
