Have you checked earth's?
Only.one I'm missing is the one from gearbox to body but I've just go the cable today.
I'll check when I get home ill just run an earth from engine to battery, I also think I may of possibly put the connector for hazard switch wrong way. Lol
Missing or dodgy earths cause all weird electrical problems . Yeh try running a earth from battery to engine .
.............it was the hazard switch........*rols eyes* hahahahaha
Hahaha least you sorted it.
Looks that way mate haha.
I've just got a notification from track and trace to isolate for 8 days so looks like I'm getting bits done on the car while sons at the childminders lmao
I kind of got it started today, having issues with the fuel pump not working then working think I might have an intermittent relay.
Also think my timing might be out as it doesn't sound right. Only has manifold on so sounds like a tractor anyway but I just don't think it sounds right lol
Here's link to a video I posted on Facebook
https://www.facebook.com/groups/2969...?sfnsn=scwspmo
Anyway I have Tuesday, Wednesday and Thursday free to do bits so I'm going to check resistance between the fuel pump wiring and if it shows there's a break in the wire I'll be ripping it out and fitting a new wire which will hopefully fix the problem.
If there isn't a break then I'll get a new relay.
I'm also gonna check my timing because I have a feeling its out from the sound of it, even though I checked and checked and quadruple checked the timing when I first did it lol.
Have you had it running with the sfi box on as there will be unmetered air which wont help and cause it to run crap. ?
