Spraying
Right i plan to go about spraying door handles, boot handle, skirts and such other faded grey exterior parts.
Whats the best stuff to use for it ? Will i need to be using primer and stuff ?
Probably will be respraying in a dark grey possibly black ? What would be the best top coat to use aswell, a flexible paint or will normal paint do ?
Cheers Guys :thumb:
The Biggest Stan :)
Use plastic primer, and normal paint.
Make sure before you ever start to paint that any silicone(like bumper gel/back to black) is off the plastic, as paint wont take to that at all.
Okey doke, thanks very mucho :thumb:
Ade's painting guide is VERY good in the Styling forum.
yeah just make sure its clean and dry. use plastic primer and normal paint. do it in a warm room or shed or sumtin for best results
Will i need to be using lacquer, i dont know if i want the shiny finish ?
up to yourself if you want a shiny finish or not
It will be ok without the lacquer on though right ?
yeah, it worked ok for me
You dont need laquer on a solid gloss base colour.
But it will help protect it from stone chips etc.
If you end up going for black mate I'd use hammerite.
Thats what I used on the door handles and boot handles for project Aspirin.
You don't even need to use plastic primer with hammerite but I did anyway.
