What is the glue stuff called that is used to seal the wings to the body ?
Cheers
Cheers
Seam sealer
Availlable from any motor shop ?
Drip Check Sealer!!
most motor shops do it although some wont becuase the proper stuff cyanoacrylate (nasty - what they use in 2 pak paint).
you can use tiger seal or similar though just dont use silicone sealer - lol
sikaflex
And the best way to get the old stuff off ? I was thinking a bit of heat ?
Why not?Quote:
Originally Posted by ade
^ becuase it smells of pish lol (really it does though!)
lol Heat it is then ?
because it perishes and water will eventually penetrate it (not as good adhesion as proper stuff). It contaminates anything near it and if you try and paint anything it goes all scabby.Quote:
Originally Posted by iainel
I've got so p1ssed off with my shower leaking in my new house and ruining the roof below I removed the "silicone" sh1te and injected expanding foam into the gaps then seamed it with boat building sealer - like sikaflex but much better!
lol
FPMSL ^ lol lol
