What is the easiest way to get the doors off of a nova?
Martin
Martin
Cheapest or easiest.
Easiest... angle grind into the door skin and cut the hinges.
Cheapest.... get a spare bonnet stay and cut it down a bit... it's the perfect diameter to knock the pins out.
Alternatively... spend ?10 on a crap tool that breaks and bends.
Edit: The pins can be a complete bitch to get out.. or come out very very easily.
would it work by using a flat head screw driver and trying to knock the pins out with a hammer?
i've got de-locked and de-handled doors and want to fit them!!!
also do you know any easier ways to get the main window in? we have got all the rubbers in but cannot see how the window will fit in there!?!?
Martin.
The pins are made of a piece of sheet metal that is curved with one edge left open. Basically they are slightly too big so when you put new ones in the leading edge begins to enter the hinge part and squashes down slightly. As you tap the whole pin closes reducing the diameter to exactly the size of the hinge hole.
Essentially you need something that is exactly that diameter.
A flat headed screw driver would work if its the same size. Just chop the end off.
I can't remember which one it is but there isn't much room to tap it.
I think when I did my windows last I had stripped everything off the door, rubbers, grey metal strips... basically the lot.
The glass has a slight curve which makes it feel like it wont fit but you just have to keep rotating it slightly to find the best way.
Also it's best to replace the pins with new ones and put plenty of grease on them. Oh and make sure your completely done with the door off before you put it back on. Trust me..... you won't want to do it again in a few weeks time.
I took the opportunity when my doors were off to paint the insides with underseal. Will hopefully help stop them going rusty from the inside out.
You need to make sure the drainage holes aren't blocked though.
Just in case you didn't know, you're supposed to tap the top pin downwards and the bottom pin upwards. To get some more room to the top one I bent the top of the door outwards (obviously wasn't keeping the door). I think I used a bolt with the right size head to push it through.
Knew I'd forgotten something.Quote:
Originally Posted by iainel
Seriously though... don't bother getting the draper tool. It's pants. I've used it on 4 pins and it's bent to **** plus the little heads that screw onto the shaft (ooo err missus) have started to round off already.
To remove the window, take everything off (rubbers, the metal spar, etc) and wind the window down. Wind it back up, but tilt it (backwards I think) and you should be able to slide it off the runner, and up out the door.
Haynes Manual has good instruction on this.
i spent ages trying to use screw drivers and drifts and hammers to get mine out.
one lash of wd40 and one of these :
http://www.toolsinstock.com/images/u...54585_DPRK.jpg
and they were out in a few mins. (just needed a 2nd person to take the weight off them.
http://www.toolsinstock.com/index.ph...iewCat&catId=4
That's the draper one that I've bent and rounded.
Mine were hard to get out. lol
I can recommend the bonnet stay approach.
Now part of my tool kit.
The tool works fine, if you use it right.... 'bad workman...' and all that jazz
Only a tool that has never removed siezed doorpins would say that lolQuote:
Originally Posted by loggyboy
i did mine the "baxter" way
dont see why the bottom pin has to be knocked up as i knocked mine down the way.
Bit of a t w a t really aren't you.Quote:
I'll second that.Quote:
Originally Posted by tom reid
Me too, had to snap some of it off though IIRCQuote:
Originally Posted by cooltom31
the bottom pin catches on the door iirc just the same as the top one going up over would
you can use the large screwdriver / hammer method if you want - ive never tried the bonnet stay method - sounds handy
The BEST way to get the hindge pins out is:
Get a bit of of 1" byt 1" box tube (thick stiff)
Cut a bit about a foot long
Run a hardstone grinder into one end through both sides of the box tube
Keep Taking a little off until you get a snug fit on the pin
oh, the cut out wants to be about 1cm deep.
Made one of these about 7 years ago and its still in use. It even removes fiesta hindges, and anyone who has done them will tell you how much of a bitch they are !
Yeah I knocked the bottom pin down on a door once. It bedded itself in to the door and made a hole in the metal. A bit of filler and respray and it was fine (you don't really see there anyway) but I wouldn't recommend doing that if you want to keep the door.Quote:
Originally Posted by rednova
that draper tool is crap, i was being very very careful with it and it still brokelol
the bonnet stay method sounds good tho will have to try it next time:thumb:
i wouldn't use a screwdriver, because if the screwdriver goes inside the pin it would be pushing sideways aswell as downwards, so would be difficult
and when i took a door off, i didn't need the shell, so took a grinder to it lol
as said the tool add some wd40
one side two minute peice of piss
other side nearly two hours a bloody finger loads of bad language and another tool after i broke the first one and the jobs done!
