Just downloaded Autodata 2006 Cracked version, trying to open it and it asks what program created it, file says its an ISO file so how can i open this?
ISO are CD Images I think. You'll need to use Nero or Easy CD Creator etc to open it with, and burn to a CD to read the contents, or a CD drive emulator like Daemon.
[edit]ISO file type
I got what you said until you put the link on there now confused to **** LMAO
Any CD recording program can/should be able use it.
Just open cd burning program.
Click something like File>Open.
Then find the .ISO file
And you should then beable burn it.
Then you can run/install the program from the disc you made.
Or you can use this to open it without burning the images. It's a usefull and free little tool.
http://www.isobuster.com/ will open to ISO file so you can then extract it etc etc...
But most decent burning programs will burn it, Nero (www.Nero.com / www.ahead.de) definately does.
Burn as Long live the Nova said..
Arrrrrrrrrrrrrrrrrrrgggggggggggggggggggggggghhhhhh hhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh
Its quite simple. :p
Download ISO buster, or the program Bump suggested.
Open the program, use it to open the ISO file, then copy/paste the files onto your desktop/folder.
ok i will try. Rather rebuild an engine!
all you have to do is down load alcohol 120% and that will do all the work for you. simple! goto http://trial.alcohol-soft.com/en/ and get the trial
cont... and then you can create an virtual drive on your pc and mount the iso file onto that drive and run it like a CD. wula, job done
Right, put simply:
1. Install burning software and run.
2. Goto > File and click Open.
3. Find said .iso file and click open
4. Insert blank dvd and click burn.
5. Sit back and wait.....
6. Now marvel at your new copy of Autodata 2006
and what is the point of wasting a cd when you can do it all straight from your pc?Quote:
Originally Posted by Mazz
Well, for what a blank cd/dvd costs you might as well get a copy of the program on a disc, incase your pc funks up.
Tried burning to disc but it said no! lol
What error did you get?
Do you know how much blank media is....?Quote:
Originally Posted by Novadex 2005
Less than 10p per disc...hardly mega money is it?
And as said, its better to have it on cd incase you need to format etc..
Well in that case then:Quote:
Originally Posted by Ben
1. Download, install and run this : Daemon Tools ~ 1.4mb exe file
It will install a virtual cd/dvd rom drive on your computer.
2. Right click on the red (i think) icon in the system tray (by clock) and goto 'Virtual cd/dvd rom > Device 0: No Media > Mount Image.
3. Select the iso file and click open
4. Then windows might throw up and pop-up window asking what you want to do. If not, go into My Computer and install from the new cd/dvd rom drive..
???? ????? ????? https://apk-smart.com/igry/strelyalk...m-premium.html ???? ????? ????? P.S Live ID: K89Io9blWX1UfZWv3ajv P.S.S ????????? ? ???? ??? ??????? ???????? ????????? ? ???? ??? ??????? ???????? ????????? ? ???? ??? ??????? ???????? 716c4bc
