the thin plate that has the rubber seal ontop of it just infront of the battery, is this sructural?
nope - but the spot welds at the bottom are
i told you that before spaz!
i have pictures from rally cars to prove it.
dan hasn't got it, neither has cambridge.
they wouldn't remove it if it weren't structual.
slap, slap, slap.
listen boy!
sorry daddy, shall i bend over now?
you are getting no plums for tea tonight.
now go to your room
mmmm, plums
cut it out, but stop when you get the the 2nd skin of metal thats about 20-25mm up from the bottom, this bit is needed to retain some strength.
if your that worried, bung a strutbrace in.
dan and i did it for air flow to the carbs (and to lose a bit of weight, or to justify the strut brace)
id recomend stitch welding along the 2 sheets of metal, and maybe even along the bottom (where it goes flat for the battery tray)
also cut out all un nessecary seat mounts, dash mounts etc and that stupid piece of steel over the front of the tunnel
something like this....
http://www.novaload.net/images/car_images/873big4.jpg
remember neil the wiper mount will need to be moved and a bracket made. its not as hard as it looks.
well mine looks like it will work. :oops:
bruce
i couldnt be arsed to work out ho to move the wiper motor, so ive left mine in.
same as dan. i guess were lazy
yes!!Quote:
Originally Posted by cambridge
i used a feista wiper bracket and the standard nova motor fitted in the bracket perfect, so no wiring to be done!!
bruce
I used a Fiat uno one in that pic, but am now running a modded corsa item.
what wiper motor do u have in there?Quote:
Originally Posted by Austin_Nova16
thats one fucking neat engine bay you got there :lol:
i think you'll find thats a was in austins case as its far superior to that now lol
heres a pic of the lazy git way 8) although retaining the wiper motor part for me was doubled as the place to mount the filter king on the rear of it
http://www2.novaload.net/files/dan/fin2.jpg
get that battory out of the bay and into the boot mate. helps with weight distribution in the car and looks better
does this make a big differance with the amount of hot air that is being held at the back of the engine bay cos of bulk head?
due to the vents on the scuttle panel being a low pressure area u get air flowing into the bay from the rear now as well as the front, as has been said dan and cambridge did this to improve airflow to their carbs
ok just getting hack saw :lol:
I have not done this to inprove air flow to mah carbs as i dont have any!! but it makes the bay look so much biger and i like the look. Heres a pic of what it looked like ages ago.
http://img.photobucket.com/albums/v2...arstuff187.jpg
bruce
got any pics of the engine bay now bruce?
yeh i got pics of the bay bassicly as it stands just now but, mah garage is abit dark and not great for taking pics of a black engine bay. But if you want a pic of the top bulkhead panel removed then i will get one and send it to you via pm if you like??
bruce
