Engine running = crap brakes?
Today I changed the pad on my GSi (Early Calibra turbo calipers with 4 stud 285mm discs) - got both calipers off, found that the nearside one had a seized piston, took piston out, cleaned it up, checked the rubber seal (it was ok), put it back in and it moved as freely as it should.
Put new GM pads in, reattched calipers, decided to renew brake fluid because afaik it's not been done.
Opened front OS bleed nipple and pumped fluid out, took union joint off the NS caliper (Bleed nipple has broken) and pumped out the remaining fluid from there.
Put new Dot4 fluid in, pumped it through all 4 corners and pedal still went to the floor, thinking that maybe air might be trapped in the master cylinder we bled from where the solid lines join the master cylinder aswell - tried peddle for feel and it was fine - started engine and it went to the floor :evil:
Bled all 4 corners again and the master cylinder unions again (no air from any of them) and once again it was ok with the engine off but when it was running it was w@nk and went almost to the floor. I've adjusted the brake pedal up as much as possible to get as much of a peddle as I can and it has worked but the brakes are worse than before I started.
Any ideas on what to so next? I'm going to take the NS caliper off next week (my next days off) to try and replace the bleed nipple just so I can get it bled properly - but failing that any ideas?
:roll:
