Nova alloy radiator. Local preferred but don't mind a drive.
Try Radtec. www.radtec.co.uk
Just had one built for mine, bit over kill for what I need but top notch workmanship. Custom to my requirements.
They do offer a Nova Turbo setup which includes the intercooler as well.
They aren't cheap though.
This might be the best option as it isn't a vauxhall engine. Thankyou very much pal. Just out of interest how much was yours if you don't mind me asking?
Actually just seen the price for the turbo setup. Mine is charge cooled. I'm looking for either a gte size or derv size in alloy. There used to be loads on eBay and now not too many.
So this is designed as a GSi sized but using a 42mm thick core rather than the 26mm (I believe) Standard core.
With the SPAL slimline fan and powder coating in the grey (standard is either polished or black) it came to ?460. But then this should be fit and forget, no plastic end tanks that can crack. https://uploads.tapatalk-cdn.com/202...68b0fc5206.jpghttps://uploads.tapatalk-cdn.com/202...16260b97ef.jpg
That's a nice bit of kit and to be fair not badly priced.
Civic ek triple core rad cut the filler cap off and weld your hose outlet on job done tiny rad work extremely well can get one for about ?65.
I recently did this one for a 7 second big block Chevy mk3 cortina . they work in anything and cost nothing . https://uploads.tapatalk-cdn.com/202...87d016f54e.jpg
Sent from my Pixel 6 using Tapatalk
And the one I still run in mine now this was when I first did it on the first buildhttps://uploads.tapatalk-cdn.com/202...8d660364fc.jpghttps://uploads.tapatalk-cdn.com/202...49121337be.jpg
Hmmm even better. The only question I have definitely involves the big block mk3....pics or link?
https://youtu.be/t0fTN9to63Q
This lad builds the motors for my car and in turn I do a bit of fabrication on his car. The rad has held up very well in it
Ahh I'm sure I know that car. At one point it was all yellow and had a massively modified rover v8 in it. I'm sure the guys name is Tim Garlick unless it's changed hands.
Yes around 12 years ago it was Tim garlicks car . and yes it was yellow Tim now has a yellow historic funny car . my mate bought the Cortina off Tim as a roller he also had a rover in it for a while but 4 years ago or so fitted the chevy
