Whats the dealio with the VX220 clocks then? Easy to wire up with the original fuel level sender, rev counter wire from coil neg etc?
Are they the same as the Elise clocks or is that totally different?
Having done some reading on here it looks like the fuel gauge reads backwards and the speedo is the problem... I have a Nova SPI transducer somewhere so wonder if that would feed it the right speed signal.
Just noticed revcounter goes to 7k rpm so isn't that great, someone please delete thread lol
There are elise clocks that goto 8
The main issue on the VX220 clocks is the temperature sender which doesnt conenct directly and needs some pissing about with. I believe the Elise ones dont need this
Ah that's interesting. I have a separate Stack oil temp, pressure and water temp gauge so I could live without the temp sender working on the dials.
Will look into the Elise ones as 8k sounds more useful.
You will need to register, but try talking to this chap as he breaks Lotus'sssss like there is no tomorrow http://forums.seloc.org/member.php?a...o&member=junks
Got these in mine. Speedo needed a transducer and a pulse converter. Rev counter on mine is abit juddery. Temp and fuel gauge couldn't get to work.
Its a cheap stack if you get a non turbo VX220 set...
i'm mystified as to why the temp sender would not be compatible... is it some unique lotus one????
as for the fuel one, a simple potential divider circuit should suffice.
No, the mk4 Astra had this funky thing too, the temp sensor goes into the ecu and the ecu then outputs a very non linear signal to the dash, maybe for rudimentary diagnostics etc but even so.
the lotus dash uses a 1:1 output from the ecu lol
typical
Plenty to read on this regarding issues:
http://www.migweb.co.uk/forums/proje.../topics/373220
I've never managed to get to a mk4 Astra ecu with an oscilloscope to test the temp in vs temp out. I know some people chuck the mk4 ecu in with bare minimum wiring to get the temp to work.
^ whs.
This was an option, but to be honest alot of messing about for a temp gauge! Many days of keen driving and a few track days and no concerns!
Also quite a good guide closer to home...
http://www.pngclub.com/forum/showthr...220-Dash-Guide
Nobody says how to successfully get the temp and fuel gauges working on that MIG link boo.
How is the fuel gauge displayed? Digitally? So if its empty it says 40L for example?
Fuel gauge and temp gauge you May get working if you were to run a mk4 ecu alongside. Seems abit of agro though. I run a fuel gauge from my old clocks. Temp gauge, I check my fan cuts in lol
Temp isnt an issue for me as I have decent stack gauges for that. What does the fuel gauge actually show then?
If its a real vx220 stack, then it shows full, 32......6,refill. If its the fake stack from the lardy rubbish turbo then its just a bar graph
Cool and the lotus will be similar I guess.
Yeah, iirc the lotus one does the bar graph
As stu said. Shows full 36 6 etc. Not 100% sure how you would get it to work tbh. I you do work it out let me know!!
As long as you can trll when it's empty and full that'll do tbh. I think I'll try and source some Elise 8k dials and follow your colour wiring guide :)
Having seen this the Lotus one is a number so it'll say 36 when empty? Is that what you mean?
http://images.pistonheads.com/nimg/2...truments-L.jpg
No. Mine said full after I installed them and the tank had a 5l Jerry can emptied in it!!
So there's no way of running it at 5-10 litres without completely guessing how much is in there, hmm OK.
come on hurry up and do a full on guide with everything working
Yeah Pete what you slacking off at lol
so temp gauge you deffo need a mk4 astra ecu installed? guessing they have a car ecu separate from engine then?
surely there is a way of making the fuel gauge work ?
cant you somehow use the vx/lotus sender?
I guess the fuel gauge issue depends on what you can install in the fuel tank on a Nova....
Another missing piece to the puzzle, Dom on MIG no longer makes the pulse convertors so not sure if the speedo would be accurate with one of those.
how come he's not doing the convertors anymore?
Nov 21 2014
Originally Posted by Dom
Game over then
from the parts manual, the Lotus Stack seems to use an ABS reluctor ring on the driveshaft as a speedo pick up. All you would have to do is find out how many teeth are on it and make your own driveshaft trigger. Probably find a corsa ABS drive shaft has the amount of teeth as the rover/toyota if youre lucky. Then use an ABS hub and pick up and it should be easy to get it to work acurately. I cant see any info on the VX gauges to see how they work.
the temp sensor thing seems odd, why not just use the lotus/VX/Rover/toyota sender with the Stack? i very much doubt it runs through the ECU first as they usually use separate sensors.
I'll dig through the wiring diagrams I have for the Elise and see what's what.
the mk4 Astra, like many cars of its era (and the beginning of the modern good era) have an engine controller (what most call an ecu) and then a body control module which is also an ecu since it means electronic control unit lol
manual: http://www.sandsmuseum.com/cars/elis...ceManual11.pdfQuote:
Originally Posted by http://www.vx220.org.uk/forums/topic/111831-speedster-elise-cluster/
fyi
I've been looking at making ABS sensor -> dash convertor for the VX folks as many want to do away with the ABS completely but its at the bottom of my development pile lol
