Mk1 Glove box with a CD player inside...
Well as some of you know my new project is all about standard grandad spec and sleeper.
This is how the interior now looks after I removed the SRi interior, changed the dash, steering wheel, gear knob, radio etc. I wanted a old medium wave radio, sourced this one from a local autojumble. Looks the part I think..
Any way obviously I still want to listen to FM radio etc so I decided to mount a CD player in the glove box.
Here is how I did it.
Take one glove box...
https://fbcdn-sphotos-c-a.akamaihd.n...23915257_n.jpg
Make a template..
https://fbcdn-sphotos-d-a.akamaihd.n...31402231_n.jpg
I used 19mm MDF as I had some..
https://fbcdn-sphotos-h-a.akamaihd.n...18702558_n.jpg
Covered in the thin Carpet found under the back seat of a Nova.. matched the rest plus its thin and easy to work with. Used spray adhesive and tacks to hold into place...
https://fbcdn-sphotos-g-a.akamaihd.n...05746599_n.jpg
https://fbcdn-sphotos-b-a.akamaihd.n...33103235_n.jpg
Fitted.. used a couple of screws to mount it.
https://fbcdn-sphotos-h-a.akamaihd.n...27806447_n.jpg
https://fbcdn-sphotos-e-a.akamaihd.n...41417057_n.jpg
I then set about cutting the back out as the radio would of fowled the back of the glove box. I marked where I wanted to cut then cut it with a 1mm cutting disc on a grinder. Used some 180grit paper to clean up the edges...
https://fbcdn-sphotos-g-a.akamaihd.n...78997937_n.jpg
https://fbcdn-sphotos-f-a.akamaihd.n...10735566_n.jpg
And radio fitted...
https://fbcdn-sphotos-b-a.akamaihd.n...44429500_n.jpg
https://fbcdn-sphotos-b-a.akamaihd.n...72374860_n.jpg
Just need to mount some hidden four inch speakers now :)
Dan
