Its there any difference in oil pumps between an early & late 20XE motor??? Or any difference in crank diameters etc etc.
the seh shows up an early/late version, with a serial no. cutoff of 14608700, and there appears to be 2 versions on the ecotec, but my ks catalogue goes all vague on the c20xe
If i remember right its only the case thats different it has a bigger/smaller lug for thetiming cover or for the late type idol roller or summet can't remember 100% but i'm sure somebody will tell us soon lol.
lug for backing pltse and the later pump has a threaded block cast onto it for the tensioner
Can be filed back slightly and used with an early backplate though?
i am not sure but from this picture it looks different
http://img.photobucket.com/albums/v3...updiagrams.gif
Cambelt cover/cambelt tensioner bolt holes/threads
can't you just get a gear kit & a new blow off valve & fit them into the old body?
i prfer to fit set of steel gears tbh the original housings are better quality than the new gms tbh
Im half tempted to use the original housing Ive got here & just fit new gears & internals. CBA to clean it though as its funking cacked in **** lol lol
Mike.. Mr muscle oven cleaner, followed by your mum's dishwasher.. You know it makes sense, but the tea cups might taste funny for a couple of days..
Its enough to make you want to kick something when you find out a bodger was there first...
Fair enough
Right so, got a new pump this morning...
However, the old one Ive got had take off for oil cooler, a new one he was supplied with the car has no take off for oil cooler but fits my XE block & crank fine? With regards to a relief valve type affair though, well there isnt one on the new pump???
Confused.net/very
Is it a case of simply putting a sandwich plate on my new & Im away as I could do with getting this bottom end tied up & done ricky tick now.
EDIT: Looking at 2.0 8v & 16v oil pumps on the FAI parts catalouge (website) they all look the same as to what Ive got here?
Yes swap sandwich plate to new pump if you want a cooler, just use the long bolt that goes through the middle of it. Or if you're not bothered about a cooler don't bother
Relief valve, take the one out your current pump and fit that?
