so whats the score with running a diesel on this stuff then? theres lots at work and fuel prices take the piss
need to fit a flux capacitor for it to work
see david fox 234342433563 he's doing it iirc
mix it with thinners..
It will want filtering first and will want a decent additive adding to every tank.
You may want a fuel heater too
david fox thin`s it out with petrol, iv got a load in the garage that needs turning into fuel for my car :) just one point luke, you ent got a diesel???
hes a pikie, he will sell it on the road side lol
50/50 mix with diesel
careful though, seen some cars in at work with some sort of ****ed up diesel in them, come in with complaints of running problems and no power
theres about 20 barrels at work of old oil so if it means free fuel i'll get a diesel as i put 30-40 a week in at the mo
well ive tested and found 50-50 with derv on the cav is ok and i keep a spare diesel filter with you in the car just incase of any issues,it runs lovely on it but any crap or water in it then it doesnt like it,id only put in whats come from a car straight in the tank,IF you put some in from whats stored at places in the big drums then you will only get trouble
umm might have to get a TD cav again, we throw away 100+ ltrs away a week lol
Might try a tad in mine, do you filter it first David?
i would lol
Hmmm My 5w30 powered Nova, I like the sound of that!
i filter it only through a gauze though,id only use good used oil,not worth the hassle if it has crap in,doesnt run any different though i change my filter every few tanks as i like to keep it reliable for sake 0f £7
So say change the filter once a month?
as oil is lighter than water & will 'float', simply syphoning it from high up in the drum using a clear hose will solve the water issue... but i reckon running it thru a decent filter, before putting it in the tank is a must..
i'm thinking an old style CAV296 as found on all old tractors, plant, and diesel stuff from the 60's as the elements are pence..and it has a water trap.
http://t1.gstatic.com/images?q=tbn:A...__W3hPiiLljYEr
