ok, if i had a 1.2 carb engine, and a 1.6 8v, could i fit the inlet and carb and dizzy? would thios work with drilled out jets?
IIRC the dizzy drive is different on the cam, i used an ast2 in my 1600 8v to run a 1200/1300 dizzy set up.
id atleast fit a twin choke lol
Why dont you try a 32/34 DMTL Webber.
the manifold would be a crap fit on the 1,6 head,
ok, so it would be easier to mpi it? the nova is carbed and will be used a s a daily, but i have a habit of over revving 1.2's and killing them...
1.6 block
1.3 head,
webber 34/32 carb
1.3 cam
1.3 dizzy set up
but carbs are gay
Leave the carb alone in the museum where it belongs.
:eek: :eek: How? lol.Quote:
Originally Posted by Rob
You must be leaving it late as hell to change.
Tbh though the 1.2's are what 0-40 for new engine, maybe worth replacing another 1.2 carbed engine after you blown it rather than faffing around converting it to mpi.
Orrrr change gear earlier :p ;)
put bike carbs on the 1600 - job done
or fit the V6 into the corsa C
:pQuote:
Originally Posted by draper
i have a habit of revving carbs past 8k....
fit megajolt and a limiter then if you really cant control yourself that much
Accelleration, you're doing it wrong.Quote:
As you've obviously got elephant feet then fit some arp bolts and an omex limiter IMO.
size 12's....
omex soft cut yeah?
You need some edjamacation my boy.Quote:
Originally Posted by Adam
There's nothing that a 850cfm Quickfuels carb can't sort.
Well, maybe a 950cfm could make it a bit better.
Though this will do for your 1600:
http://www.c-vis.net/demon_engine.jpg
It could do with a polish, but I haven't run it since October 2003.
/\/\ what spec is that running then? It looks a right hodgepodge of various things. I'll name it "alien vs predator 1.6 conversion" lol
pic too small i cant see it :d
Where shall we start.Quote:
Originally Posted by Southie
Steel bottom end, Cosworth Gp.A pistons, lightened 200mm flywheel with 190mm Gp.A Paddle Clutch.
Blydenstein flowed Irmscher inlet manifold (Bill built up the manifold with a TiG welder, then re-flowed it to GTE/GSi ports). Micro Dynamics 45mm bodies (they are utter junk but work), with 40mm bellmouths held on with agricultural suction pipe!. Micro Dynamics rising rate fuel regulator.
Special ground Kent AST9 cam, Kent solid lifters with special lash pads, and GM followers. Kent double springs on Titanium shims with stainless caps.
Head flowed by the best in the business. He has retired and doesn't it any more. He used to do heads for Mountune, MASS, and a number of other race/championship winning engine builders, including the "Sodemo" engines in the BTCC Williams Renault Lagunas (about 1/2way through the season, with poor results, Williams had someone else sort their engines, though Sodemo still tended them). Bills best head was 8hp away from this one.
DTA E48EXP ECU, Lucas coil pack. Mondeo crank pickup, Formula Vauxhall Junior crank wheel, Bosch Lambda sensor for closed loop management.
BTB 4:1 manifold with system.
Pumped by a Bosch inline EFI pump, which takes it's feed from an external swirl pot, fed by a Facet red top from a half size (cut down) standard GTE tank.
Dyno'd and mapped by Steve Grenauld with 190hp, and bags and bags of torque.
(The dizzy is there to bung up the hole, it doesn't do anything these days)
All of that feeds through a quaife 5sp sc/cr box with hand fettled syncros, a choice of diffs (usually 3.94, but sometimes 3.74, or 4.18 - I have a 4.53 somewhere!). Diff is a hand tweaked ZF and was set to 60% lock-up.
Standard 1300 shafts, modified hubs to eliminate bump steer and reduce ackerman to zero. Brakes are Cavalier GSi fronts and standard drums with Ferodo DS11 shoes (extra-hard!) at the rear.
All of this talk, I think I should get it going again over winter.
You should!
the only way to rev a stock 1.2 to 8k is to down shift to fast.... sloth, as ever you are talking bullsheets.
thort your going to the other side the world in the next few months. y bother just get a car that has a bit of tax and test on it till you go and stop wrecking all the novas before you go.Quote:
stu its a carb, just keep your foot down, there isnt a limiter. i saw 8k on my tim tacho regularly.
nice bit of text typing there. to answer what isnt really your business, i am going thanks, but seen as the celica is pretty much sold, i/we need a cheap daily, and ive been offered a 1.2 with a dead motor. how am i wrecking all the novas? and if ypou have nothing constructive to post, dont.Quote:
Originally Posted by Danny s-p
Flol
I read that spec on the 1600 on the previous page, it say coilpack, bazil says to himself " why the dizzy then? "
I fail lol
Jacking the lifters up around 8K acts as your limiter.
Plus the carb is a natural restrictor etc.... nevermind hey slofff, you believe your gauges
What bloody spec is that, our old racing 1.3sr only revved to 7500rpm and that had quite a bit of balancing, lightening etc etc!!!
Bazil - dizzy, him fill hole in end of cam carrier, stop oil coming out.Quote:
Originally Posted by bazil
In days of yore, before electricity, nobody was making nice simple hole bunging thingys. Something for the next rebuild.
How the hell do you kill a 1.2? they are near indistructable and take plenty of abuse. Sure I've seen a few peope on here having to do real daft things to make them go bang, 100Hp of Nitrous etc. Did you forget its a manual and drive everywhere in first?
yup, realised that when I saw no leads on it lol, I have an old 1.2 dizzy I'll cut the end of and get the lad in work to plate the end of.Quote:
Originally Posted by C612DNM
8,000rpm... did the vtec kick in yo?
Shame the alarm clock didnt.Sorry but that is an absolute bag of knackersQuote:
Originally Posted by Saloony
He must be on Oz time already... give it a few hours
:)Quote:
No apparently xmas John... he said it must be trues
lolQuote:
i thought the rules stated spamming threads was not allowed? or in english, get fukked
*Goes to check the rules on starting a spamming thread* or in english stop talking ****, now feck off on the horse you rode in on.
