Best App to create PDF.
As above really, want to back up some of documents I have to PDF so I 1) stop needing to reference my books or documents, 2) stop these original documents from being damaged 3) file away original documents to save some space.
There are quite a few programs out there that can 'make a pdf' file but I want a decent program that can use jpegs and also allow some word documents to be changed over too.
Anyone recommend a particular programs? Does PNG admin use pdf converters?
Any genage will be very helpful
Thanks :thumb:
Must of the designs I do are done through Adobe applications, Illustrator, Photoshop and Indesign all of which are programmes used through out the print industry.
All of the programmes come with the ability to make a PDF auotmatically.
Also some thing to help you CLICKY and CLICKY
Hmm thanks Southie, for me it would be PDF'ing scanned doc's & images, digital images and word doc's.
Will take a look at those links there :thumb:
I wouldn't pdf scans/images - you'll be able to get better compression just using jpgs or similar - all a pdf writer would do is up/down sample them depending on the settings anyway. To be honest most of the pro software won't be much use unless you're converting from it's native format. Cutepdf is a good free jobbie, installs as a printer so will work from any program.
For Word docs then Cute PDF is alright and free. Just have to go to print and select it
But some stuff all I have is scanned images so it will have to do. Thanks anyway, I have downloaded the doPDF program and will try that out, see if it's any good.
+rep coming your way (if it lets me) :thumb:
If you already have images just play with formats/compression, you will save more than pdf-ing them. If you have adobe then fireworks would be your best bet.
The lastest version of MS Word allows you to open a .doc and save it as .pdf
Hi, If it's none conf stuff then i'm happy to pdf stuff for you. I run a printroom and have tonnes of different applications that could do it.
Drop me a pm if you like.......however im not at work this week !
at work we all use
cute PDF as mentioned above
it works wonders and does many more programmes then the office suit
Cheers for all the help lads. It's not confidential stuff but there is loads of it. Gonna have a bash at doing it myself.
I know its not for converting Word or Photoshop files but I sometimes use when web browsing the Firefox plugin to save PDF's. CLICKY
