does anyone know the torque setting i need for C14SE head bolts?
Cheers peeps!
Cheers peeps!
Stage 1 25nm ( 18 ibf ) then 3 lots of 60 degrees.
FT is all you need dude lol
dont tell him that ffs, we will have 40 "whys my head gasket popped..." threads....
you dont need new bolts either!
look in this thread.
http://www.pngclub.com/forum/showthr...ghlight=torque
im wi spud ft
3 seconds on an air gun :P I have actually seen someone do that before :o
Originally Posted by Sloth
Cheers for that sloth, im not a complete elbow biter! ive done head gaskets before, im just used to a 13N engine, and not having a mk3 astra im not likely to have the haynes manual for one...! trouble i have is, my torque wrenches lowest setting is 28 Nm.... which is w*nk.
Quoted from the Haynes manual as I ain't a mechanic :pQuote:
Originally Posted by Spudly
nice one southie, god knows what im going to do about a torque wrench, mine wont go low enough...
yep, mines the same £15 torque wrench, i just set it just belowlol torque settings should be written on the leaflet you get with the hg set anywayQuote:
Originally Posted by Mk1'SR'Dan
ive been jammy there, the engine is out, ive built a timber frame/stand for it and used some strips of metal bolted onto the manifold studs to hold the head down to avoid having to take the head right off because i only needed to change the cam box, all done now, just got to torque it down, so, i should just set the wrench as low as it'll go? and then do the same 60, 60, 30?
could do with the setting for the flywheel bolts too... mission.
35nm then tighten 30 deg and then a further 15 deg
looking like its going to be worth it though...
http://i797.photobucket.com/albums/y...n/Image038.jpg
nice one mate, i dont suppose you know if theres anything i can do about the problem ive got with the head bolts do you? someones said25 Nm but my sh1te torque wrench only goes as low as 28Nm...?Quote:
Originally Posted by johnny_turbo
dude, just set it slightly below 28NM, but not so much the adjusters slack, its what i did! its either that or get one that reads 25NM
cheers jon, do i still do the same 60, 60, 30 afterwards? or do i need to adjust that to make up for the difference of 3Nm? i just really dont want to get it all built up and then blow the head gasket after a week thats all...
all done, got my torque wrench down to 27Nm just about, and did the 60,60,30, hopefully it'll be alright...
Amusingly this topic is how i ended up back on here, i was looking it out for a mate:
http://www.pngclub.com/forum/showthread.php?t=19951
/\/\/\/\/\ That's an old thread. Have you done it yet lol
yep, will be fine, i've done the same on a few cars, a couple of nm won't make much difference, chances are each hole would use difference amounts of torque to get perfection anyway
nice one jon, was contemplating getting an engine crane today but no-ones about to help me get the engine down the stairs...!
Southie: Aye, the engine ran perfectly too, then was removed when i fitted the 16xe, sat in my garage for over a year, then was converted back to SR spec and fitted with a spi inlet manifold and installed in my mk3 Astra.
