Can anyone help find where these wires go to i know they are part of the electric window and central locking loom:confused:
http://i275.photobucket.com/albums/j...g?t=1247917481
http://i275.photobucket.com/albums/j...g?t=1247917499
the red and black go to the fuse box,
do you know which fuse?
down the far right hand side of the fuse box they are plugged in. the windows are switched live and central locking is permanent.
Whos been welding and burnt through your wiring loom, by the way your welds are going very rusty, you need to sand back and treat that quickly lol
As said top right corner of the fuse box they plug into specific shaped plug holes, im guessing you may not have the plugs but you may be lucky and have the terminals in the fuse box if not, the windows piggyback off fuse 11 i think and the locking just needs a feed from anything permanent live, ignition would usually be the best way!
So they don't go into one of the numbered fuses?:tard:
No, top right corner of the fusebox there are single wire plug holes, they each individually plug into one of those, hang on ill nip out and grab a picture of my fusebox to show you!
*edit*
The power for the two circuits comes from the top righ corner of the fusebox, you can see there are two single female terminals and the power connections for the locking and window looms plung into each of these, one is permanent live for the locking and one is switched for the windows, just above where you can see the numbers 58 and 30, these are the two i mean...
http://i8.photobucket.com/albums/a36...f/DSC03454.jpg
Ant the locking/window loom should have these two plugs on it at one end, they simply plug into those two connections...
http://i8.photobucket.com/albums/a36...f/DSC03455.jpg
Hope this helps ya dude!
Good man very helpful thanks for that!:thumb: Don't suppose you know where the wires for the light buzzer goes do you? the one in the door frame that goes off when you leave your lights on?
Does anyone know what goes into the opening with 30 above it?
im confused i have got the central locking working in my mark 1 1985 L using the standard vauxhall loom however the electric windows do not work can someone please confirm exactly which fuse opening on the right hand side is for the electric windows really dont know what i am doing wrong.
cheers
al
sorry to hi-jack, just got a question, does this central locking deadlock ? if not can you get deadlock central locking for nova's ?
thanks :thumb:
