lolQuote:
lolQuote:
What did you remove the bracket with a pick axe? lolQuote:
Now now at least this ponse gets on with relocating the washer bottle - how is yours going btw lolQuote:
I could just weld it back were it came from, but if i have the choice were it goes i might as well take advantage of that....Quote:
I saw that at Edition 38 last summer it was trick as funk :cool: :cool:Quote:
Originally Posted by Ash
One of the better ideas! the further back it is the more pipe work though lolQuote:
Originally Posted by LiquidPug
Dar thanks for the constructive input unlike some - how do you fill it?Quote:
Originally Posted by Dar
Benn a valid suggestion also.
errrr he pours water in it :confused: :wtf: idiot.Quote:
pick axe? it was a track car that flew around a track, and not sat in a garage on a ponsey spit for weeks on end ;)
I said how does he fill it not what does he fill it with.....and it was a track car that flew around a track, and didn't sit in a garage on a ponsey spit for weeks on end until you got scared and sold up like a big bum fun lover XXX :wisewood:Quote:
how does he fill it? lol what a question...
i think you're referring to my champagne nova just gone, and not my whtie one ;)
lub you. x
Oi, i ressemble that comment!Quote:
Oh have you still got the white one then? ;)Quote:
The washer bottle looks like it might be awkward to fill in the place that its located so i asked how he fills it...quite simple...a bit like your fine self lol
behind the passneger seat on the floor with a long bit of pipe. the empty bottle etc is a few hundred grams and at best it holds two litres if you run the small one.
I would never consider running without washers, or two wipers fr that matter,a dirty screen is really distracting
If there was enough room behind the passengers seat and i could access it easily then it would be a possibility as i don't think i could get to it that well i think its out for now.Quote:
Originally Posted by alistairolsen
Run a bit of pipe along the roof, put a 1way valve in the end, the other end put into the bottom of the pump, other to the windscreen washers. :D
Did that make sence or is my **** talking again?
