Mines a x16xe.Quote:
If yours has a metal upper inlet, and no air flow meter, it IS also a x16xe :thumb:
Feel your pain, been there done that. Cracked the corner clean off the sump.Quote:
Originally Posted by Adam
lol
There weak as fook.
The metal has literally just ripped open on mine.
Never had these problems on the small block i tell thee :p lol
yup... done that many times to XE sumps before too lola
Correct I do have the metal upper inlet but this has been attached to the C16. The wiring I have just acquired and AFM is for the C16. Its only a temporary fix anyway to get it running so I can get the bikecarbs on (when I saved some brass up for the ecu off sbd) :thumb:Quote:
Yup, so you have a x16xe which you are going to be running on c16xe management/ecu.... :)
:roll: So adam, is your cheap 20xe power starting to cost more money?
....that would be better spent on smallblock TB's....:pQuote:
Originally Posted by MC
Ash, you were reading my mind weren't you!
Hi Ad
Did the valve thingy do the job ok ?
