Hope so, just when i think im doing ok it goes and snotters big style. Flat surfaces are by far the easiest, manage to make that look not to bad lol
Lol, I have a few tips in welding car, as they are so different to proper metal lol. Pm me if you like
Its not now
Well I braved the cold yet again, Finish my front strut/torret/ inner wing..
Basically made some spacers to move reinforce the torret mount or what ever you want to call it.
https://fbcdn-sphotos-a.akamaihd.net...71167805_n.jpg
Then I made this to go on top, exactly the same as the other side.. should be very strong indeed :)
https://fbcdn-sphotos-a.akamaihd.net...53273542_n.jpg
From above..
https://fbcdn-sphotos-a.akamaihd.net...62649416_n.jpg
I then wired wheeled the rest of the underseal and brush painted the inner arch with Zinc primer, once it were dry I went round the edges with etch primer. They will all be seemed sealer and spray primed, stonechiped, then gloss painted with 10l 2k once eventually :)
https://fbcdn-sphotos-a.akamaihd.net...16004873_n.jpg
https://fbcdn-sphotos-a.akamaihd.net...92564473_n.jpg
I cracked on making the wing support like the other side then drilled all the new holes to mount it :)
https://fbcdn-sphotos-a.akamaihd.net...02351872_n.jpg
and the wing fitted...
https://fbcdn-sphotos-a.akamaihd.net...98857508_n.jpg
As the cross member was now finished I decided to drill the holes for the rad and tie bar mount, then I gave it a good wire wheel and primer. The Inter-cooler mount do need moving though, but that is a job for when I can actually fit the bumper etc.
https://fbcdn-sphotos-a.akamaihd.net...46181159_n.jpg
https://fbcdn-sphotos-a.akamaihd.net...57510602_n.jpg
And How I left it. Definitely getting there now :), just front chassis legs, sill and both arches to do :)
https://fbcdn-sphotos-a.akamaihd.net...39488533_n.jpg
Shes definately coming along mate, although you might need another engine to pull all that metal you putting into it lol
I think you would be surprised how heavy the rust is I have removed. I will weigh the car when its done, can't see it being much heavier tbh. But I don't really mind as long it is strong :)
Bloody hope so Kev :)
Fair play dan keep cracking on lad will soon be summer so pull your finger out lol looking good though lad!
