Not sure i'll make port on sunday mate! My girlfriend leaves for dublin every sunday so it's hard to make it to the sunday shows. Take plenty of pic's if you go!Quote:
Originally Posted by stuartyj21
Keith
Keith
Well folks, again not much is happening with the car.
The gear selector is now painted satin black and refitted (no pics :() However I just can't seem to get a good finish on the brake servo, so I may just buy a new one.
I ordered a new bearing for the equal length driveshaft and got to work fitting that. This basically holds the shaft to the block of the engine, so that the two outer shafts are then simaliar length. (will make more sence when I've the engine back in)
Old bearing and bracket removed:
http://img.photobucket.com/albums/v3...7/100_3703.jpg
New Bearing:
http://img.photobucket.com/albums/v3...7/100_3704.jpg
Fitting to the shaft (needed pressed on)
http://img.photobucket.com/albums/v3...7/100_3705.jpg
http://img.photobucket.com/albums/v3...7/100_3706.jpg
Gave the bracket a de-grease:
http://img.photobucket.com/albums/v3...7/100_3707.jpg
And bolted it back on:
http://img.photobucket.com/albums/v3...7/100_3708.jpg
Finished product:
http://img.photobucket.com/albums/v3...7/100_3712.jpg
I'm ordering up my Gaz Coilovers this week hopefully, this will then see the rear end finished with brakes, suspension and the speedlines fitted.
Also the flocked dash should be back with 10 days (guy doing it is on holidays)
Keith
i have just read this from the start (cant belive how long it took melol ) absolute mental build mate ! hats of to you !
Good good keith, things should start picking up pace again soon!!!!
Good work Keith - Keep 'er chappin :)
http://img.photobucket.com/albums/v3...ect/14nova.jpg
What camera did you use to take these pics?
as said up there somewhere /\ looking good as always, keep it up!
Any decent Hi-Res camera will produce results like that if you know how to use it :thumb:Quote:
Originally Posted by jaysnova
Gaz Coilovers ordered from Chris today :)
No real update, but Coilovers and dash should be arriving this week. If the weathers good i'll have the car on its feet, and rolled out into the driveway to fit the dash.
Keith
