post them to me and i will soilder some wire on and you will have to have a play like i did lol
lol just need to know what i need(plugs for oil sensors etc),and what pin to soilder what wire's too!
Take the hole unit apart and you will see 4 pins.
All i did was soilder 4 wires on then some heat shrink over the top.
now this is the hard bit.
Were the pins went through there will be 4 little holes.
I used a reamer and made this into 1 big hole and fed the 4 new wire's through.
Now to this day i still dont know which one goes to which as i just did trial and error till i got it write.
1 will go to an earth (brown on car loom)
1 will go to a switched feed (black on car loom)
1 will go to a light feed (green grey on car loom)
1 will go to the oil pressure gauge (blue yellow on car loom)
I just kept switching around till it all worked.
lol, OK dude, i might try find the wire-to-pin correct colorings, Cheers
if you can get the plug with some of the loom still on it it will be easy mate.
Do you mean the cally twin pod guages? should be normal vaux surely and match up.
It is easy to do if it comes with the plug but when mine didnt i just soildered some wires on and played till i got them to work.
Numberplate light looks cool mate!!
cheers fella.
so when would you want one knocked up then ?
Ernie you've gone all :gay::gay:lol
