So does yours work with 2 little flywheels or something? Most I've seen seem to be an airtight plunger and a barrel?
Yes, it has two flywheels. They spin up with the first trigger then the second trigger pushes the dart through.
Mowgli, can you find me some rigid 17mm OD and 14mm ID plastic pipe ;)
Mike goes back into the garage with some tubing....lol
Iiiinteresting, see that sounds easier to get a bit more go from than air pressure, seals are always difficult. Although you're limited by the friction on the dart eventually.
With all the interest in shooting each other it makes me wonder if a PNG paintball event is in order? Those that have bought guns have probably spent more than a day out paintballing already.
