If i see it at PVS can i right a note on the roof in marker lol.
You can allways spray over it lol
the paint maybe fecked but no!!Quote:
Originally Posted by NovaLad
Why didn't you run the bonnet pull down the drivers side?
Only reason mine was a bit of a pain was because i didn't want any of it in the bay, its long enough that you can still fit it in the std way (thru the slam)...
Just an fyi, insides paint is good. All the insides going all black?
its actually not black, its a dark metallic grey, tis all sparkly :d when the car gets out in the sun ill take a better pic of the colour.Quote:
today i bolted the beam on and started playing about with various shocks and springs to see how low i can run, it was at the point i noticed one of my rear billies is screwed :cry: which is a fecker as they are the only ones that go low enough. anywho some pics of fooking about
my brother bolted on his wheel to see how silly it would look lol
http://i12.photobucket.com/albums/a2...t/SAM_0437.jpg
very silly, so then wheeled it out to see how it was sitting
http://i12.photobucket.com/albums/a2...t/SAM_0443.jpg
http://i12.photobucket.com/albums/a2...t/SAM_0445.jpg
fairly low but no where near low enough for my liking, looks well though out of the garage
i then thought i would see how low i sit in it, to be fair this is without the seat foam but i facking love being this low, with the foam im about an inch higher.
http://i12.photobucket.com/albums/a2...t/SAM_0446.jpg
http://i12.photobucket.com/albums/a2...t/SAM_0449.jpg
we then pushed it back in and decided to see how low the fks could potentially go
http://i12.photobucket.com/albums/a2...t/SAM_0453.jpg
would need **** loads of work to run this low, the sill is 80mm off the floor like this, with 14's and lower profile tyres i hope to get that to 50mm off the floor :D thats the plan for billing
another pic of the back
http://i12.photobucket.com/albums/a2...t/SAM_0452.jpg
Awesome work! Loving the lowness! And haha at you sitting that low...
I have the prob with the saloon arches, that it doesn't look as low cause the arch lips sits so much higher than the hatch (where it follows the tyre) if that makes sense.. Sill to floor is lowness is good.
exactly, on the back if you follow the line of the top of the bumper thats the hatchback arch i believe lol, its then you realise how low it is.Quote:
the surprising thing with it that low is how wasy it is to get in and out of still
Lovin the drivers position! I've still got my old tubs if u want them? Rears r easy to get low its the fronts that r a pain.
you say that, i either need to modify my chassis legs or beam lol. let me have a look at clearance tomorrow and ill pm youQuote:
On the rear the beam is gonna be constantly in the top part of its arc. The chassis leg isnt too much of a problem (from memory) its the shape of the inner arch. Ideally beam mounts need moving up & tubbing ideally.
The front ur wing lips will need sorting and ul need to tub the inner wing to run low low.
80mm is very low, let alone 50mm. Mines being setup at 100mm ride height and its gonna need major work. That is on 17s running a 598mm diam.
the beam is actually pointing up lol, the handbrake cable guide is only about 5mm from the chassis leg so will probably come into contact, another part is close to the lower inner arch seem so needs fetling aswell.
the main issue on the front is the inner arch is going to need cutting and moving lol which is crazy.
not sure what my diameter is, ive got 185/55/15's at the mo
this is only going to be my show set up, every day running will be much higher
