28 spline ffs ive just checked...the car was on a J plate 1992.
Looks like its big block shafts and hubs then lol
What gearbox you going to use then ?
J i think i still have some 22 spline shafts...
So my alarm goes off at 8am I open my eyes and I felt really positive about what i had got to do today thats until i look out the window and its was pi$$ing it down how annoying!
I pace around for a bit in frustration and prayed it would stop whilst thinking of all the jobs i couldn't do in the rain (welders and rain don't mix
), once i had eaten breakfast the rain had eased off some so out side it was.
Rain
http://i248.photobucket.com/albums/g.../NovaTD245.jpg
A couple of pics of the eps from Edd cheers bud
http://i248.photobucket.com/albums/g.../NovaTD247.jpg
http://i248.photobucket.com/albums/g.../NovaTD246.jpg
As rain was still a threat i decided to strip the suspension down as for some unknown reason i took it off the car in one
http://i248.photobucket.com/albums/g.../NovaTD248.jpg
http://i248.photobucket.com/albums/g.../NovaTD249.jpg
http://i248.photobucket.com/albums/g.../NovaTD250.jpg
Some spannering later, ready to be cleaned
http://i248.photobucket.com/albums/g.../NovaTD251.jpg
The weather was on the change for the better
http://i248.photobucket.com/albums/g.../NovaTD252.jpg
out came the welder but it was short live, I had enough time to do a bit of repair work befor i got wet.
The o/s inner wing were the boost pipe used to run needed some attention, but first i had to repair the repair section lol
Repair section
http://i248.photobucket.com/albums/g.../NovaTD253.jpg
Grot
http://i248.photobucket.com/albums/g.../NovaTD254.jpg
The boost pipe hole to be filled
http://i248.photobucket.com/albums/g.../NovaTD255.jpg
A bit like this
http://i248.photobucket.com/albums/g.../NovaTD256.jpg
I cut the grot out and marked out a new section to go it
http://i248.photobucket.com/albums/g.../NovaTD257.jpg
http://i248.photobucket.com/albums/g.../NovaTD258.jpg
And welded her home - not the best job but it will do as it had started to spit by now
http://i248.photobucket.com/albums/g.../NovaTD259.jpg
http://i248.photobucket.com/albums/g.../NovaTD260.jpg
Cleaned it up all ready to be welded in next week
http://i248.photobucket.com/albums/g.../NovaTD261.jpg
http://i248.photobucket.com/albums/g.../NovaTD262.jpg
And cut out some more rust to be replaced
http://i248.photobucket.com/albums/g.../NovaTD263.jpg
I also cut this small section out of the new td chassis leg so i could get at the second skin when welding it in
http://i248.photobucket.com/albums/g.../NovaTD264.jpg
http://i248.photobucket.com/albums/g.../NovaTD265.jpg
I will weld the cut out back in
http://i248.photobucket.com/albums/g.../NovaTD266.jpg
It was now raining heavily so back inside it was and on with stripping the engine
The old inlet
http://i248.photobucket.com/albums/g.../NovaTD267.jpg
Cavalier heater hoses and engine loom off
http://i248.photobucket.com/albums/g.../NovaTD268.jpg
Inlet off
http://i248.photobucket.com/albums/g.../NovaTD269.jpg
Marked up the injector pipes to save later confusion and removed them
http://i248.photobucket.com/albums/g.../NovaTD270.jpg
http://i248.photobucket.com/albums/g.../NovaTD271.jpg
http://i248.photobucket.com/albums/g.../NovaTD272.jpg
http://i248.photobucket.com/albums/g.../NovaTD273.jpg
Leak off pipes off and injectors out
http://i248.photobucket.com/albums/g.../NovaTD274.jpg
Along with the oil cooler
http://i248.photobucket.com/albums/g.../NovaTD275.jpg
Then i boxed a selection of bits up ready to be cleaned at work - job done for today
http://i248.photobucket.com/albums/g.../NovaTD277.jpg
Cheers mate i will keep that in mind, i'm not sure what i'm going to use yet. The 22 spline stuff might get destroyed by diesel torque thats if the gear box doesn't die first :dQuote:
F18 to start with as i already have two unless anyone has any better suggestions?Quote:
Originally Posted by comptoncj
some awesome progress.
keep at it :)
i think diesel is the new petrol
Good to see you pulling your finger out for a change! ;)
x
Well done for the fast work am impressed
Cheers chaps
