It's set by the king pin inclination, so in the case of a nova, it's the angle between the bottom ball joint and the top of the damper piston where it's in the top mount. So the only effect of changing that would be a slight change in the way the spring/damper compresses.Quote:
edit: angle meaning relative to flat ground. Draw a line through that angle, where it hits the floor, that's the point you measure scrub radius from. Forget what the point is called now tbh.
