you could run a piece of alloy pipe
is that just going to heat the coolent right up tho ?
this is my current plan.
http://i30.photobucket.com/albums/c3...oolanthose.jpg
but as you say it will heat it up no end.
the exhaust will be heat wrapped.
Your header tank needs to be on the other wing really.
Regards to that pipe cant you run it the other side of the wing, holesaw 2 holes through it?
god paul you come up with some great ideas lol.Quote:
Originally Posted by Paul
the header tank, your right, the other side would make my life 100x's eaiser.
and as for the pipe i will need to have a look at the suspension set up as it all sits very close there. but certainly an idea.
paul - you are a legend
just went and flipped it to the other side (one advantage of having the car on the drive lol) and not the routes are alot better for the cooling.
will have to relocate the FPR but it wont be an issue.
have a ****ty picture
http://i30.photobucket.com/albums/c3...6/85c8e189.jpg
Best to plan things more dude, its like the saying mesure twice cut once!
And again its a cooling system, keep any pipes well clear of the manifold dude!
thanks scott.
im one of those people who will think about most possibilities. but this is my first time lol, im still learning.
im glad someone else has come along and said it. im very open to learning a batter way etc.
some rosejoint sexyness for the panhard rod.
and a plug for the coolant sensor donated by damen.
thanks alot dude.
http://i30.photobucket.com/albums/c3...6/5bdebdde.jpg
some more small bits sorted, crank sensor, temp sensor, TPS sensor, and the coil pack sensor. - only two missing which i have already.
http://i30.photobucket.com/albums/c3...6/2f5883f0.jpg
TPS in place
http://i30.photobucket.com/albums/c3...6/7840ea9b.jpg
brake servo fitting
http://i30.photobucket.com/albums/c3...6/64d63a28.jpg
goes here
http://i30.photobucket.com/albums/c3...6/5d14bc31.jpg
and finally new expansion tank place and pipe work (thanks paul)
http://i30.photobucket.com/albums/c3...6/5fbb7952.jpg
just done a small amount more.
pulled of the old windscreen washer pipe work
http://i30.photobucket.com/albums/c3...6/682c365e.jpg
worked some magic with new pipe work - looks so much better
http://i30.photobucket.com/albums/c3...6/b3ed2a4a.jpg
and also picked up some jubliee clips.
http://i30.photobucket.com/albums/c3...6/51cb58bf.jpg
