lee, go to a builders merchants & see just how cheap you can get some plastic 'aco' style drainage, it comes in 3m lengths & has an integral grid on the top, which would be dead easy to cover in plywood instead..... you'll trip over the groove so many times & wish you never did it..
oh, i thought you were just running a lowered channel out to the door....
i was on about this stuff...
http://t1.gstatic.com/images?q=tbn:A...EPksC90wcBdaAI
just remember that the drain pipe will be needing some form of anchorage, or it will float up thru the concrete, and the concret will be quite weak there too.
what we usually do is saw cut it wider for a start, then rattle some out with a kango then use the saw to cut it further in. you end up with a stepped edge, whic helps support the repair section afterwards.
just get a cheap sds type thingy from a diy store & when it knackers up , get a new one on warranty, then sell it
